19. okt 2006 12:52
Afmontering af Forkofanger...
Jeg jackede lige den her fra et anden Swift-site...
Den var meget brugbar da jeg selv skulle hive fronten af, for at få sat min nye gril på....
Håber folk kan forstå den engelske, jeg gider ikke lige umiddelbart oversætte det hele, men kan være behjælpelig hvis der er spørgsmål.... smilie
TOOLS NEEDED - 10mm socket and ratchet, 1 skinny flathead screwdriver, 1 medium sized phillips head screw driver, cup (or somewhere to store all the screws and bolts)
TOOLS MAYBE NEEDED - jack and chassis stands
STEPS:
1. Open bonnet and remove the four 10mm bolts that hold the top of the bumper to the front beam. These are found above the top grill along the line where the bonnet latches down.
2. Remove the two round black plastic locating clips attaching bumper to car. These are near each headlight, just below the four 10mm bolts removed in step one.
3. Now you'll see two extensions of the front bumper on the very top of it that latch into the front beam. Lift each one up and push slightly back to unlatch.
4. Using philips head screwdriver, there is a screw inside the guard at the top, holding the front bumper onto a bracket on the quarter panel. Screw is slightly angled towards the rear of the car down. Remove screw.
5. Pop out each of the black securing clips on the edge of the inner guard (these hold the inner guard to the front bumper) Using flathead screwdriver, stick end in groove (you'll see a flat groove with a round head) Twist screwdriver and shimmy until round part pops up. Pull out with fingers and remove from hole. There are i think about 4 to remove inside the guard, and 1 underneath it (parallel to the floor)
6. Repeat steps 4 & 5 for other side
7. Underneath on the bottom (car may be needed to be jacked up for this part, depending on lowness) there are three 10mm bolts with washers holding front bumper on, one in middle, and one each to the right and left. Remove these three. While there also remove two more black securing clips with flat head screwdriver. These can be found outside the furthest two 10mm bolts.
8. The only thing that is holding the bumper on now is four plastic clips on each side, on each quarter panel. This bit is quite difficult. To remove bumper, lift bumper up towards quarter panel gently yet firmly, and also pulling away from the car. (This is much easier to understand when putting bumper back on, and may take some practice to get off). Repeat for other side. Then gently shimmy front bar away from car slightly
9. For those with foglights, remove the globes by turning counter-clockwise and pulling out, once out they just hang down.
10. Voila! Move away from car, bumper in hand.
Removal of front bar is complete! And obviously, to install front bumper, start from here and work your way to the top!
19. okt 2006 13:40
Lolle127 skrev:10. Voila! Move away from car, bumper in hand.
Kanon Guide der Lolle.. Stod selv og tænkte på det igår, da jeg afmonterede Resonnanskasse..
Specielt nr.10.. Der var gået fuldstændig i stå.. smilie
Men cool der,,
Jesper
19. okt 2006 14:01
lidt fra service manualen smilieForum billede
POPPER SS 4X4
23. okt 2006 13:13
Jeg har lige monteret tågelygter på min.
Afmonteringen af kofangeren kan klares på ca 10 min. smilie
Fin skitse smilie
Hellere lille og vågen end..................
23. okt 2006 14:33
Hey panik...
Hvor meget arbejde var der i at få sluttet tågelygterne til...? Er det noget der er lige til at gå til..?
Og hvad med knap i kabinen osv... Følger der det med eller hvorn, hvor har du købt...?
23. okt 2006 15:50
Jeg forhandler selv de omtalte sæt. De er komplet med alt. (knap, ledninger, relæ, strips osv.) Det er de samme som Suzuki sælger. altså originale.
Det var nu første gang jeg selv skulle monterer det, og det gik ganske smertefrit.
Jeg havde kun et lille problem med at finde en ledning i motorrummet der skulle kobles til, men det er jo meget normalt med lidt "begynder vanskeligheder" den første gang.
Hvis du har adgang til en lift kan det gøres på ca. 1 times tid.
Ellers kan du bare give lyd, så finder vi nok en god pris på monteringen. smilie
23. okt 2006 20:15
Hey Panik
Jeg kunne godt tænke mig et bud på hvad montering af tågelygter vil koste - gerne incl tågelygter smilie
24. okt 2006 09:46
Tilbud er sendt som PM smilie
24. okt 2006 15:34
For at du kan montere tågelygter SKAL kofangeren demonteres.
27. nov 2006 23:02
vil da også gerne ha en pris...
27. okt 2007 22:58
Der er godt nok ikke sket noget i denne tråd længe...
Men tjek lige her... - Der bliver linket til denne tråd, i Swift club SINGAPORES forum... smilie
swiftclubsg.com/forumv1/viewtopic.php?t=2178
Muligt at det kræver log-in, det ved jeg ikke, for jeg har det, og den logger automatisk ind, men vi kommer vidt omkring med denne side hva... smilie
Edit:
Nåh... - Sorry, nu kan jeg se at den linker til log-in siden... Men det der var i det, var at der var en der ville forklare hvordan man smider en Suz's swif sport luftfilter carbon kasse på en 1,3 / 1,5 - og i den forbindelse linkede til denne tråd, for at forklare hvordan forkofangeren kom af.... smilie
13. sep 2008 19:01
Det er lige det her trin 8 jeg er lidt bange for, og ikke rigtig forstår.
Altså. Løfte opad?
Det går da ikke, for skærmen er da over kofangeren, så den kan ikke løftes opad.
Og hvis jeg brækker udover, så er jeg banger for at nogle klips går i stykker.
Kan nogen forklare det her trin 8 en gang mere for mig?
Skal jeg stå foran bilen og brække hele kofangeren oppad?
Eller skal jeg stå lige ved skærmen og brække opad? (Som jeg tror ikke kan lade sig gøre).
