13. feb 2009 14:02
Org. Antenne
Hey, er det en det har prøvet at skifte antenne, en ell. flere spasser har knækket min smilie
Så hele basen skal skiftes, øv smilie
smilieSkal himlen ned og er det lige til smilie smilie smilie
13. feb 2009 17:42
Har ikke haft fat i den, men vil tro at du kan komme til den ved at pille kabinelampen ud, men er ikke sikker da der er i den værkstedshåndbog står følgende:
Antenna Amplifier Removal and Installation
S4RS0A9306025
NOTE:
Antenna amplifier incorporated with antenna
base.
Removal
1) Remove head lining referring to “Head Lining
Removal and Installation: in Section 9H”.
2) Remove antenna (1) from antenna base (2).
3) Disconnect antenna feeder from antenna base (2).
4) Remove antenna base (2) from vehicle.
Installation
Reverse removal procedure noting the following.
• Tighten antenna base mounting nut to specified
torque.
Head Lining Removal and Installation
S4RS0A9806002
WARNING:
Refer to “Air Bag Warning: in Section 00”
before starting service work.
Removal
1) Remove sun visor (1).
2) Remove room mirror (2).
3) Remove dome light (3).
4) Remove front pillar trim (1), front side sill scuff (2)
and dash side trim (3).
5) Remove front seat belt upper anchor (1), center pillar
inner trim (2), center pillar inner upper trim (3) and
rear side sill scuff (4).
6) Remove tail end member trim (1).
7) Remove rear inner trim (1), rear side lower trim (2)
and rear pillar trim (3).
8) Remove assistant grip (1).
9) Remove head lining clips (2) and remove head lining
(3).
Installation
• Apply adhesive (1) to head lining (2) as shown in the
figure, and then install head lining (2).
• Tighten sun visor screw to specified torque.
Tightening torque
Sun visor screw (a): 4 N·m (0.4 kg-m, 3.0 lb-ft)
Udklip af instruktionen.
antenne
himmel 1 2
19. feb 2009 15:43
smilieTak det var en stor hjælp smilie
19. feb 2009 15:57
i må godt skive vis himmel ikke er lim i bil smilie tak
