Product Type Navigation system with DVD player, LCD monitor and radio
Intended for Vehicle
Dimensions & Weight Details Main unit : 17.8 cm x 16 cm x 5 cm - 2.5 kg ¦ Hideaway unit : 18 cm x 14 cm x 3 cm - 0.7 kg
System
Form Factor In-dash
Enclosure Type Full-DIN
System Control Bus IP-Bus / AV-Bus
Supported Devices TV tuner, CD changer, DVD changer, satellite radio receiver, DVD player
Digital Audio Format Dolby Digital output
Display Controls Volume, fader
Control Features Touch panel, rotary encoder
Security Features Detachable faceplate
Features CD text, rear-facing camera capability, ID3 tags support, dual-zone capability, iPod compatible
Built-in Display
Button Backlight Colour Green, red
Monitor
Type LCD monitor - in-dash unit integrated - motorised
Technology TFT active matrix
Diagonal Size 6.5\"
Image Aspect Ratio 16:9
Resolution 1440 x 234
Widescreen Modes Full, Zoom, Normal, Just, Cinema
Analogue Video Format NTSC, PAL
Features Automatic dimmer, anti-glare coating, touch screen
Radio System
Type Radio tuner - AM/FM
Total Preset Station Qty 24
Response Bandwidth 30 - 15000 Hz
Signal-To-Noise Ratio 75 dB
RDS Yes
Supported RDS Functions TP, AF, PI, TMC, PTY, PS, TA
Features Best stations memory, D4Q, Pulse Noise Suppressor (PNS)
DVD
Type DVD player - in-dash unit integrated
Media Load Type Slot-load
Media Type CD-R, CD-RW, DVD-R, DVD-RW, DVD-ROM, DVD, CD
Audio D/A Converter 24bit / 96kHz
Dynamic Range 95 dB
Signal-To-Noise Ratio 97 dB
Response Bandwidth 5 - 44000 Hz
MP3 Playback Yes
Amplifier
Max Output Power / Channel Qty 50 Watts x 4
Continuous Power / Channel Qty 27 Watts x 4
GPS System
Type GPS receiver
Receiver 8 channel
Voice Navigation instructions
Aerial External
Waypoints 5
Routes 6
Waypoints per route 5
Features Gyro sensor, built-in RDS-TMC receiver (RDS-Traffic Message Channel)
Connections
Connector Type 1 x composite video/audio input ¦ 1 x composite video/audio output - rear ¦ 1 x composite video input ¦ System components control bus ¦ 3 x audio line-out
Er der med følger også controller til ipod så du har bare og skal sætte din ipod til.
er lidt over 1år gammelt men fejler ingen ting.
Kom med et bud.
2din følger med så det kan sidde i swiften!
                        Kenneth Jensen
